Hi, i know there are a lot of threads about superglow and i searched veeery long and i didn't find an OEM solution, the only solution i found always in the threads is the installation of a push button on the main relay (called Wilson switch i think) . I want to make my original superglow system work properly again.
My Toyo: Landcruiser BJ42 1983 24V with 14V plugs (new). Super glow with orange glow light.
My problem: Cold starting. The system is supposed to make start after 5 sec of preheating (24v to the 14V plugs via the round relay on the radiator). Then the afterglow for approx 20 sec is giving opprox 10-12V to the plugs via the other relay.
On my rig the plugs get only low voltage on the bus bar. (10-12V). So it only starts properly after the afterglow period (20sec). I tried to start after the glow light is off (5 sec), but there's no chance to start.
What i chacked with FSM:
The plugs are ok
The start relay, the glow relay, the two relays on the radiator
The 2 fusible links in the engine compartiment
The temp sensor on thermostat housing
The glow trimer (i opened it, there is no fried/burnt part)
Any ideas? What can i check?
Thanks for helping
Gilles
The plugs are ok
Thanks for helping
Gilles
