What is the thing with the 3 brass fittings? I don't remember that piece on mine.
This SC pkg still contains the ringed fan that is inappropriate and does not cool as well as the stock fan?
So, there is the added mod of getting a 3.slow fan and cutting the shroud + possibly aux electric fan?
It is a ringed fan. I do not have an old one to compare it to, so I can't tell you if it is just like the old ones or not.
So, I looked at the boxes and walked away for a while. It was rather heart breaking to think that such a cool bit might be toast due to some package sorting machine gone awry. After a 4 hour cool down period I came back and started sorting through the carnage.
So, one box got beaten a bit harder than the others. I started there. Its a credit to TRD that this piece survived. It had room in the box and apparently landed so hard it pierced the box with one of the brass connectors. Through the little box AND the packing crate.
Was there any packing material in this box?
The stock super fan is the early 3.slo ring fan, that is known to explode. Dan is running the later 3.slo fan (non-ring), it's reported to move more air. The 3.slo fans are smaller (OD) than the stock 1FZ fan, locally we were working on putting a 3FE fan, same OD as the 1FZ fan, but both owners got rid of the supers due to overheating problems in our desert climate.
That was my first thought. You can't blame UPS for a heavy object boxed up loose with no packing materials.
Most everything in the pic's seems to be boxed improperly. Hopefully it is OK because there is no way UPS would honor an insurance claim.
My guess, it's all about keeping the CARB approval.
Your CARB laws make us all suffer. JkI guess this might make more sense when I look at my S/C kit when it comes, but I am confused as to:
1) why you can't just run the stock 1FZ-FE fan with a S/C? Fitment issues?
2) Why doesn't Toyota supply a better fan than the ring POS for their $3700 S/C kit if the stock fan doesn't fit? Perhaps the non ring fan?
3) What year/model does the 3.slo non-ring fan come from the factory on?
3.5)Anyone have a rough price and or part # on said fan?
4)With having a smaller OD than the stock 1FZ fan, is there a difference in the fan blade pitch that makes it push more air than the stock 1FZ? It seems counterintuitive.
Thanks!
I think you can quite easily blame UPS for this damage. Just think about it, CDan didn't manufacture these parts in NM. They came from a factory, probably in Japan. If they made it from Japan to NM in mint condition, as Beno states and I believe him, then the fault is clearly on UPS for the damage that occurred between NM and NE.
For $3700, UPS had dang well better honor any insurance claims. I made them replace my new radiator two years ago because they dropped it on the fill bung hard enough that it was caved in and unusable. And that was with it being packed in the expanding foam material.
Excellent point and one that I overlooked. TRD cannot change the kit even if they are aware of an improvement. Pity.
-B-
