supercharger specs
IIRC it is an Eaton M90 and with the factory pulley it should have a max boost of about 6.5 PSI.
Maybe someone else can confirm this.
I dropped off the head from the build I'm doing at a machine shop. I talked with the guy about porting the head and he asked for specific info concerning the SuperCharger.
I need to know which Eaton compressor is used and how much boost these this produce.
Thanks
The supercharger is a standard issue (late style - known as "high efficiency" = 1993>) Eaton M90 Roots type. With 3.2in pulley supplied with the TRD kit, the boost is rated to be maximum 6.5psi. With a 2.00in pulley maximum boost is rated at 12.50psi
Scott J
94 FZJ80 Supercharged
