supercharger on a 94?
CANADA
want to know what i ahve to do to run a super charger on a 94, if its possible, what mods have to be made etc? fuel managment etc
Well I don't know Jack S.... really, but I did stay at a Holiday Inn Express. ( Sorry for the old qliche')
But at the moment I am looking at buying a '94 with a rebuilt motor and a TRD supercharger.
The current owner and his mechanic have had a tough time with the set up. They run premium and had to do a lot to the computer. Had to retard the timing, etc. Sounds like it was a pain to get it to run at all on the '94. They had trouble with the AC lines getting in the way and had trouble with some of the pulleys.
Maybe they just don't know what they are doing !!!
Someone replyed yesterday with the comment that Toyota recommends the supercharger to be used on the 95.5-97 models.
I posted some questions in the 80 series tech section yesterday.
Some of the replys might help.
Hopefully one of the gurus will jump in here for you.
Good luck. It can be done apparently, but it is not as easy as it would be on the later models.
fuel management will be your biggest hurtle with overheating a close second.
The 505 for the PAIR valve was designed by TRD for the SC onto the 93-95 80's, otherwise the applications (M90) are identical. Fuel management doesn't 'need' to be changed, it can be, that's no different than a 95-97 app.
Overheating would be common to both gen engines, if it's ascribed to 1.
I took my '94 truck with 113k on clock, bolted up the SC (ignoring the headgasket 'mandatory' warnings), and have run the truck for 37k since, including 5000lb+ tows.
The only mod I'd recommend considering would be the larger exhaust, and relocating the PCV valve per my description. My original exhaust started getting blown apart after about a year and a half... The PCV valve relocation appears to have been done by TRD, and not included in the SC kit.
The SC is a great mod for the 94 IMO/E, especially if torque is your motivator...
HTH and my .02
Scott Justusson
'94 FJZ80 Supercharged
the 93-94 trucks have an inherent lean condition at WOT while the 95-97 trucks are rich. I myself think that the lean condition is a little different and of more concern.
For me I ditched the idea of a SC because of the over heating possibility. But that is a personal choice and I've been told that I'm too particular about the temps my engine runs.
I dont' agree, my truck is rich at WOT as well. It's lean at the transition to boost from vacuum, that specific condition is not inherent to the MAF equipped trucks. A solvable issue.
I think if you compare the heat generated by a turbo to the heat generated by a supercharger, the heat generated by the turbo is much greater. A turbo directly taxes oil and water temps (since it's cooled and lubed by oil and/or water), and retains the heat in the exhaust. The supercharger is a sealed unit, and has a much lower and relatively constant (to ambient) charge air temp output.
If you think it's the opposite Rick, I can send you some references.
Cheers
Scott Justusson
94 FZJ80 Supercharged
Cheers
Scott Justusson
It has nothing to do with which system generates more heat it has to do with which system deals with it better. You can throw out all that theoretical BS and just look at the posts the forum members have had. You yourself have posted about having trouble controlling the engine temperature.
My comments where based on reports from forum members. The people who run a SC on the OBDI trucks have had pinging problems and resorted to adding water/methenal injection to solve it. You yourself stated that an injector change and RR FPR was needed to tune the fuel system.
No need to send me anything, just post them up here. I'm sure others would like to see them.
Rick
The statement that less heat is generated by the turbo appears incorrect. Can you expand on the statement 'which system deals with it better'? Which system/s are you speaking to? Turbos generate more heat in producing boost. I have posted my solution to low speed trapped heat in the engine bay. I do not believe that an injector change is needed to tune the fuel system yet, and have posted that. The RR FPR is needed IMO (and the BEGI adjustable RRFPR possibly desired), but that has to do with the accepted practice that fuel injector pressure differential is a constant in the calibration of ECU software programming.
Dan runs meth injection, and with low speeds and high torque rock crawling in high heat, and given his setup, I would expect him to. What I believe you fail to recognize is that there are no turbocharged systems on the 80 without intercooling. Dan could add intercooling and get rid of the meth, and/or he could do some other mods to get rid of the meth.
You can get SAE 870704 and/or acquire Automotive Supercharging and Turbocharging Manual by John D Humphries to get some background on the topic of supercharger vs turbocharger heat generation. SAE 880258 and 860103 are specific to heat geneaton of water vs oil cooling of turbochargers, not applicable to the Superchargers.
Cheers
Scott Justusson
Sumotoy, I posted my opinion on what the poster's biggest issues would be. You took exception to that and I responded with how I came to that conclusion.
I feel that I've provided the supporting info for the basis of my initial statement.
Any more discussion on this should be done in a new thread as not to high jack this one.
Mine has been in operation for a few years now. No problems. Was installed by Slee.
I'm an owner of the SC truck application considered in post number 1. I put forth that I not only disagree with your summary statements of lean fuel and overheating issues, but provided the supporting documentation 'you' requested in post #7 of this thread. And, added clarification to some of your misunderstandings of your overheating conclusions.
No hijack intended, nor new thread necessary. All addressed post 1 and your response to it. To directly answer the question in post 1, no mods 'have' to be made, it's designed as a bolt on kit from TRD.
HTH
Scott Justusson
