Supercharger hoses
Lompoc, CA
My nine year old S/C hoses are cracking, so I'm planning to replace them with silicone. I'm pretty sure the four large ones are 3" ID, but does anybody know the size of the single small one under the intake runner?
Thanks, BigMac
3" for the large, 1.5" ID for the bypass hose.
Of course, the manual tells you all this already :)
You can find the manual in my s/c install webpage ->
Kazuma Supercharger Install
I replaced my top hoses with silicone a couple of years ago due to cracking. Haven't replaced the bypass hose... yet...
cheers,
george.
Thanks much, guys. If I can get away with NOT replacing the bypass hose that would be fine for now. Next decision point is when to send the blower out for an overhaul. It has ~90K miles on it and still puts out 6 psi with little noise, so again, I'm in no rush.
BigMac
I went with Brits, AKA Sporthoses.com for some of mine. They have most Samco brand hoses in stock (blue), and ship from NorCal.
SportHoses.com Silicone Hose Specialists
Have used TurboHoses.com for the big ones. Also NorCal based.
Silicone Hose, Silicone Hoses, Turbo Hose, Turbo Hoses, Intercooler Hose, Intercooler Hoses, Turbo Connectors,T-bolt Clamps
You may want to check your clamps, and depending on the type replace with constant tension T-Bolt style with the tapered edges which will not gall the hoses over time.
:cheers:
Steve
P.S. PM NLXTACY about his experience getting the S/C rebuilt. IIRC he had to wait quite some time earlier this year for Magnuson to rebuild it, as the Gen3 S/C's were considered "obsolete".
Sorry, I guess I never posted up about it. Magnuson was NOT able to get any more kits to give mine a complete rebuild. Instead they just did the test and replaced one bearing. They said I was lucky the rotors were in good condition. :(
Wow, Joey, that's not encouraging news. I remember a post a while back that mentioned an outfit in OK that did rebuilds and coated the rotors with some slick/exotic material to build them up to minimal clearance. i drive my truck so little nowadays that I can probably go a long time before having to get serious about a rebuild - but it's a nagging worry now.
BigMac
BigMac
I'd be interested to hear more :(
For the record, one of the supercharger hoses is a 3.25" to 3" reducer. The instructions say it's 3.5" to 3" but that's too big. 3.25" fits the MAF just right. 3.5" is too big.
Also, in case you were wondering "Can I replace that aluminum 90 with one piece of silicone?" The answer is no... No you cannot... because it will collapse at idle...
Sorry to bring up an old thread, but the last picture is exactly what i was searching for...
So, do not replace the 90 degree with a solid silicon hose? Anyone else want to confirm this?
I can confirm it - I tried it just last year when I installed my s/c kit. Results looked just like that - at idle the vacuum pulled through the intake collapsed the hose. When revved up with a little boost, it pops right back out.
Looking for a good source for new supercharger hoses. Do any of our Mud vendors sell it as a pre-cut set/kit?
I've been considering it. I've been looking for a rubber replacement. The silicone is not making me happy because it's weeping oil. Pulling the hoses I can feel the oily residue on the inside of the hoses. But I have a feeling silicone might be only choice.
If you're going to do a kit, include the belt. I'm coming up empty searching Toyota online parts dealers for the belt too.
00602-17620-530 doesn't seem to exist - new number or discontinued?
I have two or three spares. :hhmm:
