Supercharged 4.5
Utah County
Website
www.instagram.com
I found some pictures of supercharged 4.5 motors, but not detailed. As my Gramps was installing a new master cylinder, he noticed a hose just hanging out, not hooked up or plugged off. Close by was a nipple capped off. Just wondering your opinions. Seems dumb to have a hose routed then plugged if you can just remove it completely and cap it off from the start.:hhmm:
I wish i had that blower for my pick up
That could be for the bypass valve. If it is, it pretty much disables the SC. You should show a pic of the capped vacuum port and the end point for the hose. Not such useful info to show a plugged hose.
The capped port is in the same picture and the end point it in the last picture.
Looking at mine, the hose goes under the intake manifold. In the capped end of your picture, your hose is angled up. It should go straight under the manifold and attach to a "T" vacuum line. Ill try to find a schematic or get a picture for you.
That would be awesome murf. Thanks!
If knorrena is right that the S/C could possibly be disabled if this wasn't hooked up correctly, that would explain a lot. My gramps 80 doesn't feel supercharged at all.:frown:
I think I have a few more pics that I could post up. Don't know how much they will help out in addition, but I will look...
YelloJacket: I grabbed my camera and got only one picture off before the batteries gave up :frown:.
The hose in question is the one in my picture running towards the orange fitting. You cant really see it but that orange barrel has a vacuum hose coming out of it with attaches to a "T" fitting. The hose in question plugs into one end and the other end has a hose running off to another fitting under the manifold. I know this is vague but hopefully will get you in the right are to look. You'll need a flashlight to see under there. A little tight but not too bad.
Awesome man!
If you are certain that's how it's suppose to be hooked up, then that would 100% confirm about the port cap part. Now if I could verify that nothing is suppose to be hooked up to this:
Here is the other photo that I had, but I don't think it helps...
I see in your second picture the orange fitting peeking through. Did you follow the line coming from it? It should go to a T fitting. And yes, confirmed that the hose in question comes from the 90 degree fitting from the side closest to the air filter as shown in the other pic you posted.
So......does the line coming from the orange fitting have a T to hook into or not?
Kazuma Supercharger Install
You can find the TRD manual hosted on my site - all from the above link. Should hopefully help you.
cheers,
george.
cheers,
george.
Thanks for your help guys!! Before I have any more info I will have to wait for my Grandpa to get his rig back from the shop. (He's having them try to fix the "spongy" brake problem)
Curious
How much do these kits sell 2nd hand for?, it seems like they are every were in US on the US 80 series
Curious
I am not sure if you could find one used but the new ones are $3400.
My Grandpa can't see a T-fitting, or much for that matter under his intake. I am sending him over to a buddy at the local Toyota dealership to have him take a look. Unfortunately I live about an hour from my gramps and don't get to see him as often as I would like.
I'm in the middles of tearing down a 1FZ-FE and had read your post so here is a couple of pictures of what is under there.
During the install you remove that hose that is attached to the nipple on the intake and goes to the "T".
You then cap off the nipple and attach the hose that is loose to the "T" where the original hose went.
At least get Grandpa to print out my webpages AND the TRD instruction manual from my post #12 in this thread. It has ALL the information that will be needed by your buddy at the Toyota place to check all the hoses etc. Most Toyota places will never have seen a S/C 80 and will waste hours trying to dig up info - at least if Grandpa has the printed stuff on hand it will be a simple/easy job.
My website quite clearly explains and has pictures of that Tee section of the hoses setup AND the dead hose connection on the intake body after the new routing is done. It is a part of the install that is poorly described in the TRD S/C instruction manual and it is feasible that whoever did the original install got confused in that part of the installation and misinterpreted what was meant to have been done and just "winged it"....
cheers,
george.
Oh wow. Thanks landtank! I am sure you are right! I will let him know asap! Think having that disconnected could affect the way the s/c performs?
cheers,
george.
Thanks George. (His name is also George :D) Looks like you have done 5 installs. Impressive. I just noticed the manual you uploaded on your site. He wasn't given the instructions after the installer finished. Even though I still can't see where that hose is suppose to be plugged into, I am sure it will still help. My guess is that it plugs into the "T". I am certain that this would have been figured out by now if he had the internet, or I lived closer. I emailed a link to this thread and your site to my Toyota buddy. They (that dealership) have done a few, but I don't know if he personally has.
I just realized that it was your site that one of my other buddies linked me to for slider ideas.:)
Yes, the hose that Grandpa has put the golf tee into is meant to plug into the yellow Tee. The TRD manual calls it an orange filter - which is WRONG (thanks to Christo for pointing this out to me years ago when I did my install).
Like Landtank's photo shows, the yellow tee USE to go to a short hose to an intake nipple. As per my website, once you install the new gasket and intake runner during the s/c install, that nipple becomes blocked off and no longer an air path - capping it is just "nice" to make things "look right".
Basically I'd guess the hose just "fell" off the yellow Tee at some point. It is just a press fit, over a barb - no clamp etc. Would take a couple of minutes max to push it back onto the yellow Tee. Maybe the hose has expanded over time and is a loose fit.
cheers,
george.
