Why are you looking? You can't use that flex because of the axle end bushing bind. The stock rubber will flex more than you will ever use.
There is nothing that fits the stock arm in a johnny joint or spherical end.
The bind is in the 4 mounts on the axle. NOT at the frame. Your rubber joint up there does that same thing. It bends and twists. Thats why everyone does the "hitch-pin" mod aka poor mans 3-link.
that also appears to be a 3-link of some sort. It's hard to tell on the pics. But for the 80 series, putting any joint without changing the radius (4 mount) setup will net you next to nothing, just a lighter wallet.![]()
That axle has a quick disconnect pin also on PS which allows the axle to move out of the bind so the spherical end will actually help.
