Sunroof opens automatically, real time help
Bonsall, CA
So here I am at work. I had to take a 3 mile drive to a fellow company so I step into the vehicle, turn the key and... The sunroof opens automatically. I push the 'close' part of the button and hear a click of the solenoid nearby but the sunroof is stuck. What's strange is that when I press the button my voltage gauge goes a little bit up, and when I don't press the button it goes down. My conclusion is that something is pressed permanently. So I fiddle with the open-close cradle switch but it moves smoothly, however I do not hear a click when pressing the 'open' part. Seems like a stuck solenoid (howcome?).
I see that rain is coming soon and the sunroof is open.
Yes. I've moved it back with a screwdriver (in the hole between buttons) but once I twist the key the sunroof opens again. I do not know how I am going to return home with all that rain.
My real time questions are:
1. What the hell happened?
2. Which fuse is responsible for the sunroof?
3. Anything else I can do?
At work I have no EPC and no FSM, hence the question.
I have no real solution except to remove the switch and unplug it. Sounds like the contacts are stuck or something.
Mike;
Try this link to my fuse chart, its for the '94 but may help:
FZJ80 FUSE CHART GUIDE
The POWER-SYSTEMS fuse #16 should disable the moon roof/seats and door locks.
I think the 95-97 fuse boxes are different from previous years. On my 97 the POWER fuse is the pink 30 amp in the bottom right. Not sure what else you will lose by pulling this...
FSM says:
If sunroof is operating abnormally: malfunction probability order is:
1. Relay (drivers side, interior, behind fuse panel)
2. Limit switch
3. roof switch
I think pulling the relay will disable it in the closed position. I looked on my 97, actually finding the relay is confusing - there are quite a few electronics there - maybe someone can help identify?
mike
The relay is up above the headliner on the passenger side of the roof controls accroding to the EPC.
Correct - I see that now. The relay by the firewall is Power Main Relay.
pull the switch or the relay at the headliner control panel while the window is closed and it should stay closed.
Great info ( just in emergency cases ) ..
It's in that place ?
