Sunroof Drain...
New Hampshire
I've never had a problem with the sunroof drains, until about two weeks ago...
Having read all the posts on the drains, I knew that when I saw wetness on my driver side mat what was causing it. Yesterday I tried to snake the drain with weedeater line, but I either didn't get stiff enough line (I got .95) or the clog is too great.
My question is: would it be ok to block off that drain (the passenger side works great) until I can get it unclogged, so I don't get more water leaking behind the kick panel?
PS: If anyone in the NH, ME, MA area has snaked their drain and could lend assistance I could travel there.
Thanks!
I used a trombone cleaning brush I had on hand for cleaning my Miata's drains but it wasn't quite long enough for the 80's drains. I saw debris falling out the bottom of the drain so I felt like it was clear enough even without a full pull-through. With some stiff wire taped to the trailing end, I'm pretty sure you could get it to extend far enough to stick out the bottom.
Pull your driver kick panel and check for kink in the tube where the clamp holds it behind all of the wiring.
Plugging it at the top will make no difference because the water is already backing all the way up to the top and overflowing the tray on that side unless you can always park with it sloped to passenger.
Edit: If the carpet seems to be wicking water from the rocker area check for rocker panel full of water. Use zip tie to open slits along standing seam of rocker from below.
I'll try both of those! thanks! I tell people all the time how awesome this forum is!
How far are you getting with your line?
Heavily built fine silt & pollen is like glue - - I took some time before I realized to cut the end at a angle & used a dremel to rough the 1st inch on the line.
Also, get down under the truck (your lift is enough to just slide on cardboard, the tube exits 1" forward the door in the pinched area - white 3/8" OD tube.
Work from that end too.
Also, that square trimmer line is my preferred stuff as it works better both in the yard & in the drains.
Linus, I'll try that, I never quite knew where the bottom drain was, I always just popped off the plugs (about the middle of the door under the truck) to let it drain, should I have to do that? or is there a place that is always open to drain?
I have done all three of my 80's with 095 weed eater line. The last one I did took several try's to get the line through the blockage. Might not hurt to pour a little water in the drain hole and let it sit to help soften it then try again. One time I tried it and I couldn't get the line all the way through but when I poured some water in it flushed it on out.
Does anyone have a pic of the bottom drain location?
Not sure what kind of mod was done to Linus rig (s) to extend them. Mine are black very thin vinyl terminating just below floor level inside rockers and behind wiring accessed by kick panels.
Normally they only drain into rockers and flow through little slits in the standing seam on bottom edge of rockers.
Fixed it! I think... on the way home last night I was thinking of another thing I could use to snake the drains, I was thinking of a thin braided steel cable, at the hardware store I found the perfect thing! Wire for hanging picture frames! I snaked the drain all the way through and then poured water in the top and watched it drain out the bottom! So I fixed it! Unless the water was from a leaky windshield...guess I'll find out one way or the other.
When I cleaned out my roof drains I used the ground wire out of a length of Romex residential wire to clean it out. I made an elongated loop on the end and twisted back up the length (no sharp points) and snaked it down the tube carefully. It worked great. Just as a thought, something similar to an Otis rifle cleaning cable and brush might work well, however, that might be overkill and might cause more problems than it fixes.
I was thinking this through again myself - coated bicycle line like Sram uses for shifters would def drop a pilot hole through grime.
I also though maybe my Water-Pic teeth cleaner might pulse water through - or find one at like Salvation Army. Just brainstorming/daydreaming at work today I thought about how it might be a unconventional shop tool.
Just some ideas.
Been putting doing this off for a while now and really need to get to it done, getting a tone of water build up about 6-7inchs above the drivers side grab handle. Was thinking of using some bailing wire from a hardware store and maybe attaching a metal rifle barrel cleaner to the end?? Anyone know what material the drain tubes are made out off? are they fragile enough to poke a hole in them if your not being careful?
I tried a stiffer wire, but it wasn't able to make the bends in the tubing, and I would avoid attaching anything to the end that might come loose and block it more. The picture hanging wire I bought at the hardware store worked great, and a 30' package only cost $4.50.
The wall thickness of the drain tube isn't that thick. Be careful to not poke a hole through it and I agree with Alex Fogg about getting something lost down in the tube and not being able to get it out (like a brush). The picture hanging wire sounds like a good idea.
I am just cruising around threads about this now so I have not looked at all of them. What about pressing a garden hose or air house to the drain hose at the wheel well? 150 psi does wonders, but could do even more damage I am sure.
My new truck has a blockage somewhere. But only when parked downhill. If I do that and it rains, it sounds like a 55 gallon drum of water in the passenger door. All I have to do is turn the truck up hill and it pisses like an elephant for 20 minutes. Where the hell is the water being stored???
In the rocker panel. Your front rocker panel drain slots at the pinch weld are clogged and the rears are open.
Easy fix. Insert a zip tie or equivalent into the slit and clean it out. It’s highly recommended that you position yourself directly below the rocker when doing so.
