I was trying to clean out my sun roof drains today. My question is do the drain tubes drain into the outer fender well? I pulled of the driver inside panel off and found the tube. It appeared to just stop in the jam is that correct
You should see what looks like a 1/2" thin-wall black plastic tube, cut off at an angle, from underneath. Look about where it pokes through the inner fender, directly below that.
