sucking oil
Dallas
Just changed from a po Rochester junk carb to a 34/34 weber on my 76 40 with man-a-fre header. Fired up w/in 3 seconds of hitting the key, and once i got the linkage straight, ran like a top. After about 30 mins, noticed it was down on power. Popped the hood and the weber air filter was dripping engine oil. It was sucking the oil right though the breather hose. I put some emission filter foam in the hose, changed the plugs (which were actually nice and tan.) Drove it for awhile, still wasn't running great, opened the hood and oil is leaking either from the valve cover or the inspection plate...too much to tell where. Any ideas?
got the pcv system back in place correctly??
Then po must have replumbed something. PVC connects to the the intake, did not connect to the air filter housing. Nothing changed except the breather hose on top of the valve cover.
