Sub tank question?
Oregon
OK since I have ordered a rear bumber from 4X4llabs and I am considering a OEM sub tank. I have read the write ups by Gerorge etc and they are great.
Question that Luc (4X4labs) and SOR have suggested a simler way to run this baby.
"Most of these installations have used a simple transfer pump to pump fuel from the subtank to the main tank via the vent hose." ie fill the main tank from the sub when needed. Sounds simple but good for something that will be seldom used.
Is this a reasonable safe approch to add a sub tank?:cheers:
That's how the factory did it (for petrol motors anyway).
That is what I did with mine. Seems safe enough and while cruising down the highway, you just hit the sub-tank button and it fills the main tank as you drive. With George's switch and the proper sending unit, the pump shuts off when the auxiliary tank gets low.
