Hey guys,
So I did a factory diesel sub tank install with the dual solenoids. However, I was given a gas 3 wire level sender from a fellow mud member. The two level wires go to the overhead console however the 3rd (brown wire?) goes nowhere. I noticed that when I turn the truck off, the level goes down and reads around a 1/4 tank lower than actual level. When I start it back up, the level goes back to true level.
I am wondering if this is happening because the 3rd wire is not connected where it should?
If it is, can I run the 3rd wire in some way to make this not happen? Obviously the other solution is to just get the right sender...
