SUA clearance
Vermont
How often do folks find themselves hanging up on the springs with the stock SUA setup? I like to keep my vehicles as low as possible, cutting the fenders for tire clearance, but it seems like the springs being under the axle could be a bit of an issue, especially in mud?
SUA controls the axle better than SOA, right? No need for a traction bar?
Been running pickups and 4Runner for the last 7 years, this is my first SUA vehicle.
Thanks for any info :)
I bashed my old Conferr spring plates up really really well over 15 years of off-road use, but can only recall one instance when I had to get out, look and see what was hanging me up, and reposition to get out - that was one of the front spring plates and a rock in intimate relations ;)
I have had many more hang-ups caused by the stock front mount of the rear spring, where it is outboard of the frame.
All this is in rocks, the times I've been in mud everything on the axle and springs got packed in, but it was usually lack of contact between tires and mud (due to ruts) that caused issues there.
Also looking for a source for better clearance U-bolt setups.
Spring under since '88, and I am fine with it....
Now,
That said, I have ran with and watched a lot of really well working rigs set up spring over. My next trail rig will be coils and link suspension...
Good luck!
-Steve
I know there's a 60 series area, but I figured these were more general questions....
I'm new to the forum so let me know if I'm wrong :)
I am running Dana 60 axles, sprung under, so I ended up making my own. I have installed their set up in four other trucks, they are really clean and work very well.
Good luck!
-Steve
Thanks Poser, I got the ubolts bent months ago, just gotta get off my a$$ and make the plates. Just looking for ideas. So much other stuff that seems more important.
Thanks Pin Head, I have been considering something like that too.
Thanks for that pic Pin-Head! I'm sure I could have those made up for a lot less than the $150 per axle that MAF wants.
If I had that kind of cake to spend I would, but I got other issues to spend money on right now. Thats 1/3 the cost of a Marlin Toy Box, which I definatly can't build myself....
I saw a skid type plate that looks kinda like a add-a-leaf but was designed to bolt in under the spring making a smooth surface. Being that most times when doing any work on leafs and requires removing the u-bolts I believe its said you should replace the bolts to get the correct torque on the nuts. I was thinking about just welding a skid plat to the mounting plate and drilling the appropriate size holes for the nuts and drainage.
Peace
I figured somethin out, I'll post when I'm done. I gotta go to work tommorow for a week, so it won't be any time soon.
