I know swamper makes some but that seems to be about it. I am happy with "35 inch" tires from BFG/Goodyear but am looking for something maybe a hair smaller but not quite as small as 33's. I know some of the metric sizing - is there a good streetable 34" tire beside a Super Swamper?
Yes, but it's called a 35, yokahoma geolander is a very small 35, about an inch shorter than a procomp xterrain. I had a set on my truck and they were good on the highway and decent off road. they were soft so they worked well on rock ect., but they did wear quickly. I think they lasted about 18-20k miles with a rear detroit and front posi. also they are directional so you will have to rotate them alot to keep from getting "cupping" common with directional tread patterns. The goodyear MTRs are rumored to be a little small also, but I haven't ever measured a set. HTH
My dad manages fleet vehicles and they ran geolanders on the majority of there trucks once. 80% of the tires they were running split (belts separated) within 15000KMs. From what Ive seen these tires are junk. However I am sure some have had better luck.
Cheers
My Q78 is supposed to be around a 35x10 and it is - almost exactly as advertised
my BFG 33x9.5s were barely over 32" tall and like 7.5 wide
I think Les Scwaab had a 34" tire when I was shopping a couple months ago - looked pretty aggressive but they usually have a great pro-rated mileage warranty on shop brand tires - we've got new tires for like 30% of new since they wore too fast - kinda like Napa starters, they are basically free for life if you don't mind going back to the store once a year
I current run goodyear 35's which are bout the size of BFG's and most street worthy tires. My Goodyears measure 33.5" with the tape measure, but when you do the math with gear ratios etc, the only way to get it right is to plug in the factory advertised diameter, so their number is correct, my tires actually are 34.7 or thereabouts. They seem small because the tires compress under weight. Anyway, what I am looking for would be an advtised 34" from BFG or something like that or Woody is correct, a true 33"
How about a 33x12.5 TSL? That's almost a 34". Alot of the 35s I measured were around 34" as well. Some are closer than others. I have a set of 33s that are just barely pushing 32"
