- Joined
- Mar 31, 2015
- Threads
- 14
- Messages
- 104
Quick history...
The coolant hose that runs from the bottom of the throttle body burst. I'm having trouble finding a good diagram of it, but it could be the No. 2 Water Bypass Hose? Anyway, the engine overheated. I went to Napa and bought a 1/2" coolant hose and replaced the broken hose and filled the coolant back up. The check engine light was on at this point, so I disconnected the battery and it has stayed off since.
Since then, I have seen the following behavior:
-Engine heats up quickly to normal operating temperature
-Heat takes a long time (10-15 min) after engine warms up to come out of vents, but it does eventually
-Temp gauge will go from 3 o'clock up to almost touching red, then will drop back down to 3 o'clock
My question is, could this be a damaged thermostat that doesn't react correctly to engine temp or should I be looking at something else? The fact that the heater takes a long time to blow hot air makes me think it could be something else.
Thanks!
Thanks!
