Stuck In Reverse!
Columbus, Ohio
Help! Stuck in reverse!
This is on my 73 FJ40 with the stock 1F & 3 speed. First my clutch started acting up. It was ok driving, but whenever I had to hold it in (like at a red light or when pulling in/out of a parking space), the pressure would bleed off, and the clutch would release prematurely. I wasn't losing any fluid, but the fluid was very dark. I figure that the master cylinder is going bad. But then on the way home, I was grabbing some dinner at Taco Bell, and going through the drive through. I stopped in line, and the pressure bled off again. So, I had to shove it into neutral. When I did, the shifter popped out of the transmission. I got it back in, but now the truck is stuck in reverse. If I try to put it in first, its like there is nothing there. If I try second or third, it stalls the motor, and won't move. Is it possible that the linkage just went too far when I shoved it back into neutral and the shifter came out, or did I just FUBAR my transmission? I will be towing it home with my Tacoma, then tomorrow I'll take the top cover off, but I'd just like to get an idea what to look at and what to expect. :crybaby:
When the shifter came out it was in reverse and when you put it back in, you missed the hole. Now it's in both reverse and another gear. Take it out. Use a screwdriver to make sure both sides are in neutral, then put it back in right.
Ok, I'll try that. The 2/3 side is in neutral....I can get it into 2nd and third. The R/1 side seems to be stuck, like the rail went past the limit. :bang:
:bounce: Well, all I needed was a long and thin enough screwdriver. I was able to move the gate over, then get a thin screwdriver behind the rail. A little playing with the clutch pedal while prying with the screwdriver, and it popped back into neutral. Then I got the shifter back in and drove it home. Thanks very much Eddy for the suggestion. I was worried that I had sheared off the shifter rail, and that my truck would be back to sitting in my driveway again :crybaby: MUD comes through again!!!
BTW I don't think I've ever posted any pics of my truck over here....I started my buildup thread on my local chapter of TTORA, so I've been updating it there. If anyone is interested (or just really bored) here's a link. Once I get really going on it I'll start a build thread here.
Eric's (bradleyem) FJ40 build - TTORA Forum
Thanks D'Animal. Its a love/hate relationship for sure, but more of the former...especially when I can drive it with the top off and get a thumbs up from people as I drive by :) I also love the look on kids' faces when they're looking up at me out of their parents cars.
I'm definately on a learning curve working on something this old again, but its a welcome break from 50 conductor wiring harnesses and having to have a code reader to troubleshoot.
The front is polishing up pretty nicely. I have alot to tend to as far as typical cruiser rust goes (rust that has been repaired...by sheetmetal rivited on the driver side, and cracking bondo on the passenger side :)) But for now I'm attending to the things that are important for safe driving (brakes, steering, suspension, drivetrain).
Since no one else has mentioned it, having your shift lever come out of the transmission is NOT NORMAL and VERY UNSAFE. Either your retainer is missing, or the retainer pins have worn out of the shift tower. NEITHER is an acceptable condition.
Pull the lever out and look for the pins. There should be a hole in either side of the shift tower [tnat the lever goes in] where the pins go. If they are missing, the stock ones are difficult to replace without removing the tower from the transmission. SOR sells a kit with pins that can be bolted in place [read: much easier]
Best
Mark A. [on bull's laptop, after a couple of drinks!]
Both of the pins are there, but when I had to jam the shifter to get it out of gear (because the pressure in the clutch M/C had bled off) I pushed it hard enough to bend the aluminum tabs on the collar that holds the shifter in place. I may have not gotten it completely seated when I put the transmission back in, or the tabs could have been bent already because even though the shifter wouldn't come out before, now that I've bent the tabs back and made sure that the pins seated properly it seems to be stiffer, and have less play. When I was trying to get it out of reverse last night I was afraid that I was going to break off a piece of my screwdriver or one of the pins would come out and drop into the transmission because I was trying to fix it by flashlight :doh:
