I just put my hood back on my 80 after an engine swap, guess I didn't get the hood latch hooked up right. It's stuck shut. Nothing happens when I pull the latch. Any ideas on gettin it open?
Future reference, if this happens again. You should be able to look up from under the truck and see the latch mechanism. Follow the center support up and there should be a square cutout on the mechanism frame. Stick a small screwdriver or center punch in there. You should feel the ear that the underhood cable attaches to. In the closed position it should be to situated to the passenger side of the frame. Put the screwdriver in there and push to the driver's side. This might take one or two tries but it would preempt the need to remove the whole mechanism.
