Real Time Help - Stuck Hood!!
Utah
I must have tweaked something yesterday when installing Slee's headlight harness, because now my hood won't open. I'm not able to pull the release lever all the way back either, it is stuck... :mad:
My first thought was that the cable is frozen, but the truck has been in a heated building for an hour now, and the hood still won't "pop". I've tried loosening one of the bolts on the latch itself (raised on a lift, reached up behind the grill with a ratchet) but to no avail...
Hell, I even took a crowbar to it. No worky.
What else can I do?
Most latches have a way to stick a screw driver in them to open them up. I would pull the grill (just a few screws) off and you should be able to get a good look at it. You should be able to see what is keeping the cable from pulling all the way and even grab the part of the latch that the cable attaches to and open it by hand.
I would remove the grill, but there are two more screws underneath the hood that hold it down. :bang:
LK,
If you can reach up from underneath, you should be able to feel where the cable comes in, IIRC there is an ear that it attaches to, you should be able to cantilever that backwards and open the hood.
Glen
P.S.
A crowbar should never be a consideration unless saving life and limb. :doh:
Thanks, I'll run in the shop and give it a shot.
Well we finally got it to open! Like an hour ago....:lol:
I took my ratchet and removed the three bolts holding on the latch, that allowed the hood to open about two inches. Then my buddy popped the latch with a flathead screwdriver it while I held the hood up.
I think what happened was that I pinched the cable while replacing the crossmember yesterday.
:doh:
Lane,
Good to hear you finally got it!!! :clap:
Future reference, if this happens again. You should be able to look up from under the truck and see the latch mechanism. Follow the center support up and there should be a square cutout on the mechanism frame. Stick a small screwdriver or center punch in there. You should feel the ear that the underhood cable attaches to. In the closed position it should be to situated to the passenger side of the frame. Put the screwdriver in there and push to the driver's side. This might take one or two tries but it would preempt the need to remove the whole mechanism.
Sorry I could not get back to the forum sooner and post more specific directions.
Glen
Of course, the PASSENGER side!!!:doh:
I kept trying to reach up on the driver side, but my hand wouldn't fit up there with the tranny cooler...:o
