stuck diff locks
Tucson, AZ
I have stock diff locks on my 94. I have posted before about trying to get them unstuck but I still have not been able to do it. I crawl around in slow circles on dirt and try to engage them. I have been doing this 3 times a week or so for 20 min ...i have stopped and put the key in the on position and then listened for the actuators and I can hear them both move, front and rear. kind of like a short movement and then a click hard to describe but it sounds like they are doing what they should. lights are still flashing ...CLD works well though...I have just changed my diff fluids for mobile 1 gear oil hoping this might help ungunk them. I will regear with in a year or so
I think I may just go to ARB 's at that point but is there anything I should also be trying?
Describe why you believe they aren't locking, aside from the dash indicators.
-Spike
humm did not really think about them being locked and the dash lights just not showing it. can this happen? what would be a fix for this?
There is a sensor that determines if the locking ring is in the 'locked' position or not. Another example of Toyota going above and beyond in the LC, the dash indicator tells you when the locker is actually locked, rather than other systems that just tell you when the switch is on. It's a common failure point. I don't remember if people have had any luck taking the sensor apart and cleaning it (it's a simple plunger contact switch) or if it's better to replace it. There is some information about it running around the forum somewhere.
My front sensor works when it feels like working. If my truck climbs up whatever rock induced me to twist the knob, I know it's locked. :D
-Spike
Diff Lock Switches
You can check to see if the diff locks are actually working by jacking up both wheels on one side of your truck. Don't forget to chock the other side. with the key in the on position but without the engine started and the trans in neutral engage the center diff and the operate the switch for the rear locker. Turn the rear wheel until you hear/feel the diff lock engage. It will be very obvious when it engages. The same process can be used for the front locker.
The Diff Lock Engaged switches are known for giving problems. I have had some luck with using contact cleaner to dislodge the crud from inside the switch.
Here is a link to a post I wrote on the switches.
https://forum.ih8mud.com/showthread.php?t=148605&highlight=diff+lock+switch
Good luck
