Stuck clutch
southampton ny
Hi this is my first time posting so please forgive me if this has already been discussed. I have a 78 fj40 with a 4 speed and a 2f engine and the clutch seems to be stuck engaged. When i push in the pedal it is firm, I laid under the truck and saw that the fork is in fact moving but nothing happens. If anyone has any insight to this problem it would be greatly appreciated.
Thanks
Another possibility
I had the same problem with my 79fj40. If you let one sit up for awhile in a humid climate, the metallic particles in the clutch disc will corrode and fuse to the flywheel and pressure plate. If it isn't too bad, an easy way to separate them is to set the parking brake and/or block the wheels, put the transmission in gear, fully depress the clutch pedal, and engage the starter.
Obviously, the clutch slave cylinder must be operational for this to work, but you mentioned that you had verified it.
i had it happin to mine after going threw deep water and parking after. the water suctioned the clutch to the fly wheel. i just started it in gear and drove it in first and it finaly broke free.
I have seen this condition before, and it was a spring for the disc that had come free and jammed things together so the clutch was engaged the whole time.
I would expect mechanical failure. Broken spring or "finger" in the pressure plate.
Mark...
