stroking the 2f
hey guys i was wondering if anybody has done or herd of anybody eigther boring and/or stroking the 2f? If so how big and any horsepower ideas? Also, i was wondering what mods would need to be done to get somewhere around 200hp area on the 2f ?
any input is greatly appreciated :)
Hasn't been done, won't be done. Stroking a 2F is not feasible. Not even possible without major rework of the engine.
Getting 200 horses is just a matter of taking plain old hot rod stuff to a high enough level. Compression, cam, induction, exhaust, ignition, beefing for higher rpm. You could explore turbo charging. You could explore supercharging. Both have been done to 2Fs. You *could* explore NO2, but that has very limited use for an off road rig IMHO.
Mark...
2F is really a "stroker" from the factory: larger stroke to bore ratio for low end torque. The reason it has lowish power is that is is a relatively low compression engine with relatively low displacement. I have a 2f rebuilt to higher compression (shaved head?) ; it has 185 psi across all 6. It actually requires race gas mixed in with premium unleaded to run without pinging; compression is way higher than spec and it therefore requires very high octane fuel (and yes I have played with the timing, carb settings, cooler plugs, etc etc). Lower compression motors in general start easier, run smoother, and last longer. I recommend a STOCK rebuild with quality parts. I don't note huge power gains from my 2f "racer." Build for reliability and simplicity, not horsepower. Then you'll still be driving this rig in 15 years. That is unless you want to run 43 inch swamp monsters like everyone else seems to have to, then you'll need higher power just to turn the tires.
well, no v8's for me(lest they be from yota). But that sux about the stroking. Can anybody atleast tell me what mods would push 35's happily and easily, I was thinkin enuf to move the truck liek it had stock size tires, but with 35's, if that makes any sense
A healthy, stock 2F engine and 4:88 diff gears will do this just fine.
Good luck!
-Steve
Good luck!
-Steve
Indeed. If you have to have more power consider a turbo with a small amount of boost, but otherwise either drop in the V8 or be happy with what's already there. If I remember correctly the 2F (and the F) already has a 4 inch stroke. That's tractor torque.
Rice
that sounds good to me, thanx, by the way, sorry if i confused ne one but i dont have a landcruiser just yet, im just doing my research rite now :) i just wasnt sure how easy it would push the 35's, thanx alot tho, im set now
mine pushes 33's no drama stock with tired 2f.
4 inch stroke... i'd be ashamed of that...
Not if you had 6 rods all going at once. :D
