Stripped Diff Filler Plug
1st i'd try welding another nut on, a big on so you can weld inside and outside. if you don't have a welder try a pipe wrench
old thread but having a strange problem done rear diff fluid change today fill plug i had to use a jack to slowly crack the plug after i snapped a 24mm n then a 15/16 socket on my breaker bar, but the drain plug cracked easily n just spun wouldnt loosen or tighten its just spinning its not the head on the plug it seems to the the threads are stripped it just spins its not leaking i drained the diff with a vac pump threw the fill plug hole n filled it n still no leaks. Not sure what to do
As the diff warms up, it will leak.
You need to pull the plug and address the issue.
Buy a new plug and gasket.
Get a tap that matches the threads.
Use a screwdriver or chisel to pry down between the drain plug and housing while unscrewing it with a wrench to force the plug out.
Otherwise you may have to drill out the plug from underneath.
Odds are it stripped all the threads off the plugs and the other end cannot thread through the hole because there's nothing there to force it to.
Good luck.
Pretty sure the thread size and pitch is M18 x 1.50
So when you get the old plug out....hopefully there are enough threads left in the diff housing to repair the threads with a tap or thread chaser.
IF you have a spark plug chaser....most of those already have a M18 x 1.5 on one end (M14 x 1.25 on the other).
