Strange noise coming from engine.
Norfolk, Virginia
I hope I can do this justice. Yesterday I finished tightening the last hose clamp and filling all the fluids. I have a 78 FJ40 that I have been doing some engine work on since Oct and had not been started during that time. It started out to fix an exhaust leak and eventually ended up with all the engine gaskets, hoses, and belts being changed out. The entire engine was cleaned and painted.
After a few tries to crank it over, it finally started. It ran fairly smooth, thenI noticed a thudding noise that came intermitently. When I pull the choke out past half way it is noticeable only on occasion. But when the choke iis pushed in and it idles at a lower speed the thudding noise is more frequent. You can sit in the drivers seat and really notice it. There is no squeal, grinding or banging noise, just an occasionly thud.
I have not taken it out on the street yet, but hope to soon. I have oil pressure, and the temperature stays within normal operating range.
Any suggestions on what it might be? The engine is desmogged, and for the most part stock. I don't remember it doing this before I began.
Thanks, Steve
I am no pro you should wait to hear from someone else but you say it started hard and it occasionaly makes a thud........ When you were sprucing things up did you bump the distributor accidently changing the timing?????
thud
An occasional noise and a thud doesn't seem like an internal engine part. try inspecting the entire front of the engine for loose components fan shroud hitting, altenator mount and pulleys, p/s mount etc
