Strange knocking sound
Lately on my 97 LX there is sometimes a weird knocking sound. It seems to be when my rear passenger tire goes up or down on a bump and I was just curious if Yall had any suggestions on what it might be
Sway bar bushings are one possibility. Have you gone underneath to have a closer look?
Bad shock
Loose shock
Worn bushings in the trailing arms on rear axle
Loose or worn sway bar bushings
Loose lug nuts
Loose spare tire
Loose exhaust
Worn or rusted out body bushings on RR
Garden gnomes hitting their head on the gas tank when you go over a bump
Small children trying to get your attention to stop
Hydraulics aren't working properly on your "hopper"
Subwoofer speaker in the right rear compartment fell off and bouncing in the cavity
Get under it and shake the bejeezus out of every suspension part you can wrap your paws around and you'll find it.
I have a similar problem/knock. I have a 2000 with about 170k and I have so far replaced: rear shocks, all the sway bar bushings etc., exhaust, spare tire, tires and the rear diff.
(Side note, I took out the bump stops and installed air bags and OME 1.5" medium load springs)
The knock is still there. Maybe it's the upper or lower control arms in the rear?
If I hit a bump straight on it does not knock as much as if I hit a bump with one back tire at the time or at an angle.
Did you resolve your issue yet?
Thanks!
My sway bar mount broke. I was lazy and just looked and all looked fine. One day I grabbed the sway bar and found it was not attached to the mount.
Looks for worn or missing bushing mounds. Mine were dry and almost gone on some points.
