I clean mine and let it vent for a day or so. Then close it. .... when is time to use it again it smell a bit, but that smells usually dissipates with in minutes after it is turn on...... i have read that coffee grinds are a good option as well...
This is the best known inexpensive solution that has existed for decades. Also can be used as toothpaste! It's truly a multi tool.we use ‘Arm and Hammer’ Baking Soda ... they sell boxes of the stuff with permeable sides specifically for use in ‘fridges ...works fine. Has lots of other uses as well - makes a good fire extinguisher, a teaspoon in a glass of warm water can cure heartburn, rebalance your PH and a small amount of the stuff made into a paste applied to a insect sting can relieve the pain. Probably lots more uses too.
After having mine running constantly for 2+ years, I just started storing mine propped open with the latch. What's the risk?It's not always a good idea to keep the ARB latch in the "vented" position if the fridge is mounted in the truck all the time.
