Strange electrical gremlin
Long Beach, CA
I wasnt even sure how to describe the issue in a title, so here it is:
Stopped to get gas & shut off the rig. It was running without issues.
A few minutes later, started it back up.
The “BRAKE”, “A/T TEMP”, & some other warning light was illuminated. I don’t recall which other one.
The stereo was turned off, but I had a constant static buzz from the speakers. Turning radio on & off didn’t change the noise.
I pulled over & shut off the rig. Once the key was in the “OFF” position, the starter began running continually, in the “OFF” position, starter continued the run, but the engine didn’t start. I only let this go on for about 5-10 seconds & was worried my starter was burn up if it kept going!
At this point was was pretty concerned!
I turned the key “ON” again & the rig fired up & ran normal. No radio static or idiot lights.
I turned it off & let it sit for a minute while scratching my head.
Turned it on, no issues, & drove home. Sitting in the driveway now.
The ONLY thing out of the ordinary I can think of today was my 3-year old climed in the drivers seat & hit the on-switch for the off-road lights.
The off-road lights (HID’s) were on for a few hours. Rig sat parked for a few hours at the park, with the lights on.
I noticed they were on when I saw them illuminated from across the parking lot at a restraint we stopped at for lunch, after the park. I ran out & turned them off.
After lunch, the rig started normal.
After lunch went home, off/on no issues.
Hour later, on again, no issues to drove to gas station. Problem started, & only once, when leaving the gas station.
Very strange....
Yeah, starter has been on my to-do list for a while, but it hasn’t given me any real issues yet.
I’ve already got the OEM starter rebuild kit & new heavy duty battery/starter cable kit from Fourrunner here on Mud...
Might have to think about making that a project soon.
I'm thinking your starter was stuck while truck was on and you didn't hear it maybe causing the interference noise you heard thru radio then when you turned the truck off it stayed engaged still, then once turning the truck on it kicked over immediately and came un stuck.
^x3
