A bit of background. My '71 has had a 60 series rear end swapped in by the PO (diff/housing/axles/brakes etc) and the front cylinder adjusters (drums) are seized, but I'm chucking new cylinders in next week. Rears have been adjusted fine (just sliiightly dragging).
So this morning on my way to class, some lady pulled in front of me and I jumped on the brake causing a mega lockup, followed by some threshold braking to steer around them
. Immediately after that, the brake pedal hit the floor every time I had to brake and I have to do the double-pump. I thought I had blown a old cylinder seal or something, but on the double-pump, it holds pressure...
I got it home and adjusted the rear shoes (fronts seized; remember) to just sliiightly dragging, drove a bit, and adjusted to sliiightly dragging again. Now my brakes felt as before, and I don't need to do the double-pump to lock up the rears and it's as if nothing ever happened...
Anyone keen to shed some light as to what happened when I mooshed the firewall trying not to rear end some lady that might have caused the lack of pedal that went away after adjustment? My only guess would have been the extra pressure might have moved the adjuster somewhat to be 'loose'?
Anyone?
. Immediately after that, the brake pedal hit the floor every time I had to brake and I have to do the double-pump. I thought I had blown a old cylinder seal or something, but on the double-pump, it holds pressure... I got it home and adjusted the rear shoes (fronts seized; remember) to just sliiightly dragging, drove a bit, and adjusted to sliiightly dragging again. Now my brakes felt as before, and I don't need to do the double-pump to lock up the rears and it's as if nothing ever happened...
Anyone?
