Storing large components
MDarius
I break stuff.
Bountiful, UT
So I'm dismantling my '95 Land Cruiser that was wrecked. The frame was bent and I'm not interested in making it a buggy. If somebody wants it before I get too far I'll consider offers. Otherwise, when I get the parts off and the hulk is out of my driveway I'll post up a parts for sale thread in classifieds for anything in decent condition that I'm not hoarding for myself. (Either way, the body is up for grabs. No fender flares, front fenders are shot, hood could be salvaged.)
-BUT-
That's not what this thread is about. Assuming I DO dismantle it, there are parts I want to keep for myself since I can use them on my '97. These include, but not limited to:
  • Engine
  • Axles, diffs, and related parts
  • Radiator
  • Trans cooler
  • Brake Master Cylinder and system components
  • Transmission
  • Transfer Case
  • Power Steering Pump
You'll notice I only listed items that are normally lubricated or otherwise full of fluids. Many of these are "sealed" systems. How do I store these as components instead of on the vehicle without having corrosion problems? I don't have a vacuum sealer big enough for a 1FZFE. I can handle storage of non-lubed or small parts.
At some point I'd like to rebuild the engine while it's out, that way WHEN the head gasket fails (or whatever else happens), I can swap it into the '97 in a weekend instead of having it offline for an extended period of time. Same with the other parts. Cleaned up, refurbed, ready for a direct swap.
Salvage yards usually deliver stuff all plugged up with little plastic caps, I bet you could find an assortment or something online. This would let you keep fluid in some of these parts and block off the holes so they don't leak or anything. Then maybe toss some moth balls on stuff that critters could chew and go crazy with the giant roll of Saran Wrap?
Great idea to rebuild the engine and have it waiting, that would be a fun relaxing project and then plan a weekend to swap it out...
Parts like these can be bagged in plastic with plenty of sticky oil or grease on machined surfaces. Seal the bag. Put desiccant gel beads inside the bag to defeat moisture. Check every few months on the gel beads to see if they have turned color because they start out blue when dry and turn pink as they absorb moisture. Depending on how well your bag was sealed and the environment you are in, this can happen in a week or a year or more. The gel beads can then be de-hydrated in an oven once they have taken up all their moisture.
This is how aircraft components are stored. Most people aren't so picky with automotive stuff and just shove it in the corner and hope for the best.
The gel beads can be purchased at aircraft supply shops like this:
SILICA GEL GRADE 42 FOR AN4062-1 DEHYDRATOR PLUGS from Aircraft Spruce
They also have a number of handy storage mechanisms for the gel beads, just search for desiccant.
Also for engines you can actually get plastic 'spark plugs' that hold desiccant gel beads that screw into your spark plug holes. Seal all of the engine's holes up, and install one in each hole and it will wick away moisture that can cause corrosion. Check from time to time and renew the beads when needed. Aircraft engines can sit on the shelf for 30 years and then be good to go when needed this way as long as the desiccant is maintained on a regular basis.
Damn I was just going to recommend aircraft storage supplies. At Whitman airport there are a lot of stored plane parts and I see lots of interesting things.
i learned something today - dessicant spark plugs, who would have thought someting like this exists. cool.
If you could find one with the right threads or at least an adapter, they could be used to screw into a fill plug on a stored axle.
You a pilot or A&P? Small airports are great places to waste time!
Neither :P
I have a stupid wealthy friend I met in my Film Industry days and he has the coolest damn toys just sitting in a freaking hanger.
