Storage Solutions Behind Third Row?
Cody - Do you have an image or mockup of what you are building?
Basically here is a rough sketch attached, I have dimensions for the pieces with folds and stuff as well, but this is just a rough picture. The lower drawer has a rendering, the three sections off may seem a bit redundant, but when your trying to use every inch, they should have enough space for wrenches, sockets and some other tools, which shaves space used from another place.
and the FJcruiser plans, it's pretty low (2.5") so you don't really loose any space like with normal drawers, but enough for recovery gear and basic stuff.
Picked up the bent metal, worked on it a bit this evening, gonna take a bit to get things lined up perfectly so the drawers are slick enough. A couple pics, working on the lower, the upper two aren't installed yet, but to show you the extended bottom drawer
The three small ones are attached to the back of the larger and slide under the third row
I used milk crates when I still had my third row seats in. Worked pretty well. I think I had two 1’x1’ boxes, and a 2’x1’. Third row seats could recline just a tad... but not much.
I got an hour to work on it after the kids went to sleep.
Probably gonna case the sides,top and drawer faces with 3/8" plywood of some sort. The handles would have to come off and I'll have to figure out a recessed handle. Also need one for the bottom drawer. They need a little bit of work still but they slide ok now.
Some more. The white box is my camp stove, a Coleman I sand blasted and had powder coated. Need to put some foam in the bottom of the drawers eventually too. Gonna consolidate all my tools to the tailgate storage and a drawer and organize it bit better. One drawer for camp cooking stuff in the middle.
It will be a while before I post any finished pictures, but I wanted to share some pictures of the concept
Edit: anyone use yoga mat for drawer liner? To keep the rattle of tools and stuff down?
I like it. Especially utilizing that space under the seats. Have you thought about putting a hinged lid on top so you could access the top drawer contents with the tailgate closed or from the 3rd row while underway? Or would that compromise the integrity of the carcass?
Thats a good idea. I never thought of it. But... I plan to mount some sort of cooler or fridge on top at some point so that wouldn't really work for it, and I think it needs the structural integrity.
The sides, back and top should probably have been built with strong plywood, and the drawers sheetmetal. I couldn't build the drawers with wood and have clearance under the seats, and the thickness of wood drawers and wooden structure would eat an inch or so at the back and the front of it, it's already about 13", so I'm using every millimeter I can get out of it. At some point like I said it will get plywood on the top and sides for strength, but I need to switch gears to the other projects, so it'll just be put together "good enough" for a little while.
On a personal note, a fella here made a connection to a gentleman who does really nice TIG work with aluminum, he finally has time to work on some of my projects so mounting the other turbo (rebuilt an HX35W) on the 6BT is priority, to get it out of the way, then focusing on the one tons and beadlocks which got pu on the backburne as other things came up. When the turbo, axles and wheels aren't on my plate I'll be cleaning up the storage drawers some more. So much to do, so little time.
He already did a bit of work, started burning plate on the intercooler for a top mount and we did an oil fill on the first valve cover and some other knick knacks. This week I'm gonna try and finish fitting the rest of the aluminum for the top mount IC, can't wait to get it in and see how the new turbo pushes it along. Gonna need more power if I plan to break that 14 bolt as my friend Ian says. Something to do with my driving and broken rear diffs.
I'm much more comfortable working with wood than metal but you are correct. Thickness of the wood would eat up a sizeable percentage of the usable space in this application. Looking forward to see more updates on this when you get back to it.
