Stock fuel pump?
Columbia, SC
Is this a stock fuel pump for a 1978 2F? I thought the hardline unioned directly to the pump?
It has a nipple threaded into the pump and a soft line that bends up to the hardline. Do you think someone bent up a new hardline and just didn't want to deal with the complex bend at the pump? Can I replace this nipple with the original fitting to accept the union nut and compression band?
Thanks
Jeremy
Or could someone have reversed these two fittings, and all I have to do is switch them? The fitting on the side that goes to the tank looks like the fitting I need to connect the hardline. The fitting that is pictured looks like it belongs on the other side with a soft line from there to the hardline along the frame. Am I off?
Jeremy
I'm not sure. There is not a lot of differences over the years with the fuel pumps. I am running my original equipment 69 fuel pump from an F engine on my 77 2F.
Original fuel pump easy to identify
The original fuel pump is pretty easy to identify. The OEM unit says KYOSAN on it...I think...as I have one boxed up that I never used. My original also said this.
I've had FJ40's from '63 to '78 and all of the OEM/original units looked very similar.
Thanks for all the help. I am going to switch the two fittings and get fasteddy to send me some new fuel lines.
Crazy hotsauce, I just noticed you joined in 2004, and you just had your first post. How does that happen?
Jeremy
When you go to NAPA/KRAGEN/PEP BOYS... they all say KYOSAN on them there are no afteremarket fule pumps just OEM pumps that have been sold to the aftermarket
