Stock Front Pinion Angle
I have a project that is using an FJ80 front axle.
I need to cut and turn the steering knuckles to correct the caster angle after a pinion angle change.
I have torn the axle down but can not sort a good way to consistently measure the castor angle.
Of course I have not tried all that hard yet to get a correct measurement method.
However I feel like if someone can tell me what the stock pinion angle is then I will just set it to that measurement and take a reference angle on the knuckle somewhere that gives me a consistent reading.
Then I can set my new pinion angle, cut and turn the knuckles using the reference angle I measured before.
Anyone have any clue what the stock pinion angle is?
If you're changing the pinion angle anyway, what does it do for you to know the stock angles? You could just set the pinion at 0* (or any other number) and measure the caster at the knuckles. That will give you the relationship between the two as it sits now.
As of right now I have not been able to come up with an accurate and repeatable way to measure the caster.
So if I know the factory pinion angle, which is much easier to measure, then I can set it up on the bench and set the pinion angle to the factory setting.
Then I can make a little jig or something that locates my angle gauge in the same place every time on the steering ball.
Then I can get a number from that and use it as a stock reference when it comes time to turn the knuckles after the pinion is pointed in the direction that I need it to be pointed.
Aha, that makes sense now. You're trying to derive the caster angle from the pinion angle, since you can't easily measure the caster. If someone doesn't get you a measurement before tonight, I'll measure mine when I get home.
Cool thanks. Yeah I have had to explain this to a few people but now you know what I am after. I am going to mess with it a little tonight to see if I can set up a way to just get a proper caster measurement but if you get your pinion angle by all means let me know.
