- Joined
- Jan 26, 2003
- Threads
- 26
- Messages
- 188
Have a stock fully smogged 2F that starts and drives fine and even idles as long as the choke is about 3/4 way out……however this is the weird part…..once the engine gets fully warmed up (hot) and while it is idling…..the engine will suddenly begin to rev up at very high rpm and if I push the choke back in (off) it idles back at normal and will do so without any choke. Once it cools back down the problem returns. I’ve seen other threads about a blown fuse affecting the fuel cutoff solenoid (ics) but fuses are all fine. It seems that maybe one of the vacuum switching valves (vsv) that plug into the head/water housing are suddenly ‘opening up’ or closing off’ causing the carb to dump more fuel …..has anyone else run into this problem? Any suggestions on what to test? Fuel pump is fine and is an in-line fuel filter. Thanks in advance.
