Stihl 180 ignition module?
Godwin
Resident Herpetologist
Alabama
I have a Stihl MS 180C that will not start. I pulled the plug and with it attached to the spark plug wire cranked the saw and had no spark. What little I've leads me to think the ignition module has failed. Do these fail often? Any recommendations on a replacement? I've found OEM at ca. $60 down to non-OEM at ca. $10.
Did you make sure to ground the plug on the saw when pulling, otherwise you'll never get spark. I've never had one go out, but that's just one example. I would Check the contacts on the magneto for any sign of damage, those time the ignition.
