Anybody rebuilt their starter yet? My plunger seems to be sticky at times. I know this seems to be a fairly common issue with the 80's. I've read up on some posts of how to do it, and find it very helpful, but have not done the rebuild yet.
on the scale.Was your plunger sticking at times as well?I just R&R'ed mine today as a matter of fact. change the contacts in the solenoid housing and take the plunger to the nearest starter/alternator shop to have them re-surface it on there lathe (cheap, cost me 5 bux) some people file the rough spots on the plunger, but really ...... do you want to do it again in a short period of time over 5 bux? super easy to do ...probably only a 1 to 1.5on the scale.
do all 97 cruisers use the same kit? i tried to look at the part# on my starter but couldn't find it. either its too dirty or the label is missing.I've done 2 plunger/contact rebuilds. Piece of cake. The new plunger is now part of every new contact set as it makes no sense to have to go back in to deal with an increasingly worn plunger. Get them all on the same wear slope and replace them all once versus having to pull a starter on a hot trip with no hope of parts...
DougM
I was thinking the same.Before you go just buying parts make for certain you have a factory starter and not a non-OEM starter.
Prior to rebuiling mine I found I had a aftermarket unit. I picked up a used 2.0Kw OEM starter from CruiserParts.net and rebuilt it. Then pulled the aftermarket unit and installed the new/used unit.
