sticking throttle
Cairns, Far North Queensland
Hey there
I wondered if anybody had any quick advice.
I have an '82 FJ40 with 2F and standard carbie. I have a sticking throttle - have replaced throttle return spring, lubed cable (which appears to operate correctly). The throttle seems to stick only when in gear (i can feel the pedal click very lightly) and it disengages after about 3 or 4 seconds of being in neutral (after it has revved its nuts off). I sprayed a load of WD40 at the carbie but it appeared to have no effect. Everytime I got to the engine bay, whatever has been stuck appears to have unstuck itself - so I cant trace what the problem is!
Any suggestions would be appreciated.
Thanks
Justin
It sounds like you have worn out bushings or missing at the carb. area. Where the cable come out in the engine compartment there is a "pivot point" where the cable connects to. That assy. has bushings.....check there. Is This a intermitently problem during driving conditions?
Not sure how an '82 is set up, but there's a bunch of things under the dash that could get caught in or around the pedal assembly and cause binding. For example, I had a handbrake cable that would contact the pedal arm intermittently after applying and releasing the brake on a '77. That PARTICULAR thing won't apply to yours but maybe something simple like it does.
Thanks for the info chaps
My FJ40 is an Australian model. I've checked through the linkages from pedal to carb with everything appearing fully operational to that point - the cable is oiled and appears in good condition with all bushings appearing to be in place. The cable has two positions at which it is clipped by what appears like an OE clamp to stop it moving around. I tried unclipping the cable to give it a more natural path, but it made no difference. I noticed that the metal quadrant which the carb end of the cable attaches to does not appear to fully return when the throttle is released - I think this is because the diaphragm/plunger which controls the fast idle may be defective (would appreciate advice on how a problem in this area might manifest itself or be checked as I think this may be what the problem is). The problem is intermittent, and I may be on the wrong track completely so if you think you can help in any way, then I'd appreciate it.
I'm based in Cairns, Australia and the humidity has been approaching 100% for a few months now so it may be the cause of something sticking.
Thanks again
Justin, sounds like the carb itself is kinda stickey. Try hosing the linkage and shafts down w/ some carb cleaner solvent, then chasing with a little light spray lubricant. If that mitigates symptoms, then you know the carb is carked and needs a rebuild.
