So I got an alignment about a month ago and everything was good and my steering wheel was nice and centered. I took the rig elk hunting for a week and when I got back to pavement I realized my steering wheel had moved about an 1/8 of a turn to the right. I decided to pull over and check tie rods and such. Upon inspection I found the nut holding my pitman arm to sector shaft was about to fall off. It was only being held on by a thread or 2. I grabbed a wrench and tightened it back down so I could drive home. The truck still drives nice and straight and it doesn't seem like my alignment has changed. I am assuming my pitman arm worked loose enough that it must have skipped a few splines thus explaining the steering wheel change. What is the best way to straighten my steering wheel now? Can I undo the pitman arm and turn the steering wheel back to straight or should I adjust it via the draglink?
