Steering wheel makeover
just giving some of you some an option rather than redoing the leather route of the steering wheel. I used plastidip. You can find it at any hardware store. I have had it on for approximately two years and it's worked great. I am doing a recoat as I write this. Pics to follow
Did you put it on over the leather?
Looks good how does it feel?
Question, how did you apply it? Multiple coats over multiple days? Did you use the entire can? It really lasted 2 years!? I must try this, my wheel is falling apart and sticky in the heat.
I applied it all in one application. No it does not peel. Used the entire can. The shine does dull a little over time.
I knew someone would zoom in on the odometer. Speedometer broke last year and I replaced with a new one at exactly 240k.
The idea is to coat all at once to get one molded material. I was probably spraying for over 10 minutes continuously applying the product
At least you left the airbag alone.
My 40th had a PO who added a black aftermarket grip over the leather, and felt the need to paint the airbag to match. :mad::mad::mad::mad::mad:
I wanted to punch him in the sack everytime I got in, the airbag new is ~$700.
The color in my steering wheel leather was starting to fade and when it got wet the surface was sticky. I think the previous previous owner was a heavy cigar smoker. I purchased some acrylic paint and mixed my own color to match the wheel. The center vinyl was fine so I just painted the spokes of the steering wheel. I used angelus leather finisher to lock in the color. I installed a wheelskins leather wrap to finish it off. I'm really happy with the look and feel of the steering wheel now.
Good idea! I wouldn't mind buying a big can of the stuff and filling a large pan with it, then actually dip the steering wheel into it. Flip it over and let dry face up. Might make for a thicker, smoother finish. They make Plasti-dip in all sorts of colors these days, and I know that I saw Flex-seal in BROWN recently.
Plasti dip the front grill and bull bar on the 7.3 and still looking good.
