Steering shaft diameter
Long Beach, CA
If someone has a micrometer handy, can you measure the interior steering shaft?
it appears the shaft is 3/4”, but feels like it has a small step up as it gets closer to the firewall.
I’m replacing the firewall dust shield & want to center the shaft, within the hole to get more life from the rubber seal.
I read a 3/4” clamshell bearing will fit on the steering shaft, but I’m not having luck getting it to slide all the way down to the interior side of the firewall.
I’m trying to replicate this idea, but the application was an Australian 80 with right hand drive. I wouldn’t think the shaft would be different, but I’m finding it may be.
here is what I’m trying to accomplish:
Don't. The body and frame (where the steering box is mounted) are not rigidly coupled. You need some compliance there. I did it. It sucked.
That’s a bummer to hear.
my steering shaft rests very close to the outer side of the hole. I seems that would put a lot of stress on the rubber grommet.
is this kinda normal, or should it be centered?
Any way to get it more centered?
