Due to major delays in returning a PS gearbox to scotia, as part of a warranty swap, and replacing, I had no choice but to outsource the gearbox replacement.
At a very reputable, but small, mom and pop shop two miles from house, for what should've been a two hour job, that's uncovered an issue that I can't find and threads on, so hoping that input may help correct the issue.
During free-play adjustment, tech (FJC buddy) noticed an undue amount of play, and when we were discussing, turned the wheels and he noticed quite a but of deflection in the steering shaft, itself. Upon measuring, it's almost 3/4", as best measured.
Checked all other components, just to make sure, and everything appears to be in great shape, but from the firewall to the gearbox, the shaft appears to bend (deflect) about 3/4" each direction from its centerline.
Obviously, the 37x12.5 Krawlers are exerting more pressure on all the steering components from the box down, but I wouldn't have imagined they'd affect the column, itself, even parked.
Is this an isolated issue?
Anyone know of a stronger steering shaft, or means to brace with bearing midway?
... rag joints on your link
