Last night I had an incident that I cannot yet explain. I was making a rolling (15-20mph) left hand 90 degree corner over some very bumpy rail road tracks and at about 90% of where I wanted the steering it locked. What I mean by that is I could not turn the steering further to the left. The steering would still move to the right with no more effort than normal. It felt exactly like I had come up against steering stops or something. I was able to stop, mid turn safely. I had the stereo going so at first I thought the engine had died. I turned off the truck and started it again but still could not turn the wheel further to the left. I limped off to the side of the road and visually inspected the steering parts in the dark. I could not see anything obviously wrong so I drove slowly the last two blocks to drop off my daughter. I encountered no problems (no noise) driving but when I tried the steering would still not turn all the way left. I made a couple of right hand turns (no problems with right turns) into a parking lot and again visually inspected all the steering arms, stabilizer, etc. I could see nothing obviously wrong so I started out for home (only a couple of miles to go) and this time had no problem making full left turns. At home I again inspected everything with a trouble light but still saw nothing wrong. I drove it 25 miles to work this morning with no issues.
I figure one of two things happened. Either something is loose and got caught in a bind (in which case it will happen again) or somehow a stick or something was temporarily caught in a steering part causing the blockage.
Tonight I would like to check everything over for a loose part so what I need from you is a list of parts/bolts to check that could cause this.
