steering issues
Portola C.A.
I'm sure this topic has been beat to death, but here it goes again. My steering wheel won't return to center, and still is a hand full to drive. Things I have done to try and improve, repacked wheel bearings, alignment, new 33's, adjust preload on saginaw steering box ( power steering) 2.5 caster shims. I don't have a steering stailizer on it yet but it is on the way. fj has shackle revearsle kit and 4" lift. The only thing I haven't touched yet is the pit man arm. It looks to be 7" drop. I know this subject is getting old, but everytime I drive this thing I obsess over it and just wan't it fixed. I hope I posted enough info for idea's if not let me know and i'll post more.
Hi All:
So you have four inch lift springs AND a shackle reveral on the front? That would net about six (6) inches of lift!! The caster shims you have may not be enough to compenstate for six inches of lift.
A seven (7) inch drop pitman arm? Seems like a lot of drop; are you sure that is neccesary?
Of course the $24,000 question is what you think is wrong with the steering? These rigs, especially with wide tires, do not steer or track like a modern vehicle. Can you describe the symtoms that make you pause?
Regards,
Alan
Seattle
"Black Dog" (Quote):
I should have stated that the pitman is 7" long, and
2"drop. I honestly never thought about what the total lift height might acctually be. Any who when I turn the steering wheel left or right around a corner, it will just stat there. For power steering, it sure seems stiff. Mabye it's the pump or box going bad?
thanx, Jason
Regardless of any lift or other mods.. What is the actual caster? Determining that is a good place to start.
Mark...
Mark...
X2
If you have a flat, level parking spot, you can read the caster off the pinion flange with a stock axle. The caster is +1 degree, relative to the pinion flange.
You can also read it off the top flat of the knuckle with a straight edge rules as a spacer.
What is the angle of your drag link relative to your tie rod? They should be parallel at rest. Bump steer can make it quite squirrely.
My alighnment sheet showed that castor was o.8 degrees. Then thet told me drive it see how it felt. I't felt like **it. So I added the shims with the fat side of the shim to the front of the vehicle. I'm still spring under.
