steering hard when turning left
good day,
i just rebuilt the power steering pump and power steering gearbox on my 80 due to its hard steering when turning left but when turning the steering wheel to the right you can feel the power steering, there is no leak, i used atf dexron3, after the rebuild the hard steering on the left is still there...
Did you bled the system? Sometimes it takes a lot to get all the air out. I had a 60 that it took me forever to get all the air out and showed that symptom.:cheers:
First thing I would do is put the front on jackstands, remove the draglink and manually check the steering for any notch or mechanical binding. Then with the draglink removed and motor off, manually cycle through the steering lock to lock and see if there is any mechanical binding.
Put draglink back on, and again go lock to lock without weight on the wheels and see if you can feel anything.
I have the same problem in my HDJ80! Have you resolved? In winter time, when it's cold,no problem happens, everything works fine. In summer time only when turn on the left the sterring it's hard to move. If you move on right and then on left it' ok.
Than you
Than you
if the engine is in its operating temp i find it heavy to steer this truck, no leaks just plain groaning noise from the steering pump
