Steering Greasing
Al Ain, UAE
Guys, how much grease goes into the steering knuckles?
I removed the little square plug found on top of the knuckle just behind the brake rotor guard, and started squirting away... next thing I know I'd pumped the whole gun in!
None ever came out anywhere, it just went in and in...
This was my first greasing since I bought the truck maybe 3 weeks ago, so it could have been empty, I thought.
Now I'm having second thoughts - what's your take?
The knucke cavity should be 2/3 to 3/4 full. Any more than that and you risk forcing grease into the axle housing and mucking up the differential.
Hmmm... so you'd reckon 5-6 two-finger-fulls of grease was too much?
I couldn't tell if it was full or empty, and I stopped before it became evidently full; is there some way of knowing the level of grease inside?
I'll drive it a bit and then check my diff fluid to make sure it hasn't gone straight through.
You can fashion a "dip stick" out of wire and get a rough idea of the level. It doesn't work well if you just put a bunch of grease in. You will need to drive it and spread it around.
Dan,
On a service (from empty) how many tubes of grease would you recon a knuckel/birf will hold?
And one more question
I drilled, tapped and fitted a nipple on the grease plug of my fj40 and would give it 4 shots of grease every oil/lube interval, this worked great. always had a film of grease on knuckle and when serviced birfs they where not to full.
That being said this was not a full time awd vehicle do you think this setup would over lube the knukles on an 80?
Is the objective to have a nice film of grease on the Birf-side?
Because mine was dry as a bone... after I cleaned off a baked crust of black crud I could see the gasket-like material - is there supposed to be grease slowly oozing past this to the outside of the nuckle, I mean onto the Birf ball itself?
I'll do the wire dipstick after I drive it for a few miles - thanks. I don't think it's full but 2/3 -3/4 is possible, so it should be alright.
