Steering gear
Michigan
Hello I am new here
I have a fj40 with the three on the tree
I need a new steering gear
Where would I be able to get one and how I find the right one
Thank you
Thank you for the welcome!!
We are trying to “replace” the steering gear box.
We do not have the “part number” so we picked one of three choices and of course the one we picked does not fit. The problem we r having is a jump or jerk in the steering when driving the vehicle. There is ALOT of play also. The mechanic tried to adjust it, but there is nothing left in it to adjust.
As mentioned earlier, it is a three on the tree shifting so the steering gear box needs to be compatible with that type of shifting.
What year is your land cruiser?
I would check to see if your centering arm has any play or any of your tie rod ends have play.
The steering box is rebuildable. The gears really would not have any reason to fail.
Specter off road has some awesome diagrams and rebuild parts for the steering.
Kurt @cruiseroutfit also supplies all the parts you would need to rebuild your centering arm/tie rod ends.
correct me if I'm wrong, but the early year steering box wasn't a separate unit from the steering column. later models used a rag joint to connect the column to a steering box.
the gear on the end of the steering column was a pain to try to shim
You may indeed need to rebuild the steering gear but I would replace the tie rod ends first and have a good look at the centering arm. Unless they have been changed already it may be a big part of any steering problems.
I stock rebuilt steering boxes for all the early Cruisers. And I rebuild them too, provided the sector roller is not damaged.
The change from the earlier four-bolt (as opposed to clamshell) to the second iteration of the one piece four bolt pedestal was in July of ‘69. This corresponds to the change in center arms.
So while you can’t get a pic of your steering wheel splines (36 vs 33) you can usually get a pic of the center arm which will lead you to the correct steering box.
Mark
www.marksoffroad.net
PS. I do not offer parts for rebuilding them; too hard to come by.
Hello,
Title says it is 1976 (wrong) I guess, because if I look it up now, it seems like it is a 1969 with the configuration of the three on the tree. Need to find out a way to really identify
