steering arm question HELP
I have a 67' FJ-45 with a 76' FJ-40 disc brake front end. I did a spring over and still need to finish the steering. I need to get a raised steering arm to get up above the springs. I am running a saginaw power steering gear. Do I need both sides to have the raised arms or just the passengers side? Also, since it is a 76' front end, I need the smaller bolt pattern raised arm. Any ideas as to where I can buy one? What other options do I have? Can I cut another arm off of a donor and weld it upwards onto my stock arm? Please email me or give me a call at 208-922-2992.
Thanks.
m5moore@msn.com
look up Luke at 4x4labs.com He is about the only guy with hi steer arms for the small bolt pattern.
You can also use a double arm on the passenger side, but that leaves the tie rod under the leave springs (rock catcher!)
