** STD PART - any more info?
New Zealand
Since parts guys that know the 40 series are becoming as rare as rocking horse poo, I use the EPC to work out all my part numbers and order things explicitly through the dealership. However there are lots of small fittings that just say ** STD PART without giving any hint at dimensions etc.
My current project is making a mounting system so I can use a York compressor on my BJ42.
I need a couple of 20mm long, 10x1.25 bolts and I like my fittings to be from Toyota's supply chain whenever I can. Is there any info on what the standard parts are. Hoping that someone knows something.
i use villagetoyotaparts.com for the pictures to get the part number and then buy from toyotapartszone.com here in the US.
Typically the last two numbers for a bolt are the length; example 91651-61030 is 30mm long. Not always the case, but most of the time. I learned this from the great CDan and/or Beno. I also use the diagrams at Toyomotorparts and complete part #s from Toyotapartszone. Hope this helps
