Went ahead and order a new hose and clamps from:
index
Owning a used rig is so much fun.
You will find a lot of "while you are in there..." advice here on the forum. The only thing that I have ever changed out on my LC that I was forced to was the starter (and it still worked - just had the intermittent problem). Everything else has been preventive and OCD.
You will probably want to do a coolant flush when changing the PHH. The block drain is in the general area of the PHH and you should at least drain that before attacking the hose. Just be careful of the electrical connections in the PHH area (attached picture).
I had good luck by doing the following:
1. Drain the coolant
2. Pull the hose off at the top of the hard pipe that goes from the PHH to heater valve (rear of engine - up against the firewall on the driver's side). This will let the hard pipe flex enough to get the new PHH on.
3. Reach from under the vehicle and loosen the middle bolt holding the hard pipe. This is done blind and takes a little bit of time. Some people can not get to the bolt. Just do not completely remove the bolt - just loosen it. You may be able the flex the bottom of the pipe enough without loosening the bolt.
4. Using a dremel with small cutting disk to remove the factory "sardine can" clamps.
5. Cut the old PHH off with a razor knife.
6. Pull / twist the hard pipe out of the way. I used a long screwdriver to flex the hard pipe enough so the new PHH could slip on the nipple.
7. Lube the new PHH with KY or any lubricant of choice.
8. Slide the new PHH on the engine nipple (with both clamps on loosely).
9. Twist / push the hard pipe back into place (it took some force to get the pipe to slip back on to the new PHH - lube is your friend).
10. Tighten everything back up.
Having the trans. dipstick tube and the starter out of the way give you that little extra working room you need.
If you run into a problem, just stop and take a break. This is a frustrating job, but much easier with the right tools and plenty of time.
Good luck!
Riley
