I tried searching but it pulled up too many topics not relevant to what I’ve been experiencing. So, I’ve been having an issue with my 1994 FZJ having trouble starting when it’s cold. I turn the key and the dash lights up but nothing happens. Eventually it kicks over and runs fine after that. I live in Lake Tahoe so it gets down below freezing quite often, and it seems to be getting worse. I’ve replaced the battery and the starter as well as power and ground cables in the last 6 months. Im reading 12.5 volts at the battery. I’ve also done a parasitic draw test and I’m showing 30 milliamps which should be good for a normal system. My next thoughts are maybe fuse able links or something with the gear selector/neutral safety switch. Anyone insight from someone who has been in a similar situation would be greatly appreciated.
