Starting the Engine for the First Time
Clarksville, TN 37043
I’m several weeks away from attempting to start the 2F engine in by 79 FJ40 that has been sitting without any fluids in it for the last two years while the rest of the cruiser was undergoing restoration.
I plan to leave the coil wire disconnected initially in the hope I can circulate and build oil pressure before starting it. Is there any merit in removing the spark plugs and pouring an ounce of motor oil into each cylinder a day or two before attempting to start it? Is an ounce the right amount?
What is the best way to make sure I get all the air out of the radiators and the front and rear heaters to make sure I don’t have any air blockages in the system?
I’ll probably post questions about the hydraulic clutch and the master brake cylinder/brake lines later but will consult my manuals first.
Thanks for your help
When I started my 78 for the first time in 2 years after a rebuild I didn't pour anything down the cylinders but I oiled up everything good before reassembly. I would prime everything by using an electrical drill and a large flat bit into the oil pump with the alt out. Make sure you're getting oils to the top end.
Ad far as air in the system goes just burp it soon after start up on a steep grade. And make sure you've got your radiator overflow vented.
And don't used starter fluid.
what catfish says is good, but pre lube doesn't help dry cyl walls. Squirt a couple of shots of atf fluid in the cyls and crank for a few revolutions before starting. This will help immensely and your rings and cyl walls will thank you.
make sure u install LUCAS ZDDP zinc rich formula
this is a valve train cam shaft lobes , solid lifter Skool Of Thought
@John McVicker
Yep, Lucas is the stuff I used & recommend.
Agree with what is posted above. I too would spray some love juice down the cylinders before cranking it.
For the cooling part I always just fill the rad up all the way. Have a gallon or so extra readily available. Leave the rad cap off, then while the engine is running I just squeeze the rad hose a bunch of times. You should feel it fill up and will also see the fluid drop in the rad. Then just keep topping it off and flexing the rad hose with your hand. You should be able to see if fluid is circulating by looking into the rad. Don't leave the engine running long though (no longer then 5 minutes. Once the system is full shut the engine off. Put the cap back on and you should be off to the races. Hope that helps.
All of the above is great. I'd add initially turning it by hand/breaker bar with the plugs out just in case. If it does that freely then hit the starter. And next time leave some ATF in each pot before long term storage! :)
